How can I sound dampen my corsair 300r. Tips and Guides please. I know nothing about sound dampening.
its not the best case to work with as its quite an open design - what you want is some sound dampening material
and to reduce the amount of fans and get the quietest fans possible
https://linustechtips.com/topic/356036-sound-damping/#findComment-4833074
I am getting 2 noctua in front and one in the rear. I have an Nhd- d15 cooler as well. I am looking for materials. I have the solid side panel and I just wanted to put it on and see. So what kind of material how do I apply it and where do I buy it.
Chase B
Sound Tech and GPU Expert
Are You New? Please Click on these links to help you out. Code Of Conduct | LTT Beginners Guide
https://linustechtips.com/topic/356036-sound-damping/#findComment-4833089
The best thing to do is getting quiet and lower noise generating components, mostly sound dampening prevents echoing or sound from bouncing around inside the case.
A good one is suspending or dampening the hard drives of you have any:
http://www.silentpcreview.com/article8-page2.html
https://linustechtips.com/topic/356036-sound-damping/#findComment-4835311
