I think i have finished my build and at the moment it is a 1080p x 1920p build with a gtx 970 and a z97 motherboard. But I am now wondering if I should go with a gtx 980 and a 2560x1440 monitor. also should I go with with an x99 or a z97 for the QHD build. and should I go with and z97 or an x99 if I go with the 1080p build?
Thank you!
EDIT: if you want I can give you the specs of both builds.
https://linustechtips.com/topic/356013-build-ideas/
