How small did you have in mind?
It would help to list your specs.
https://linustechtips.com/topic/355939-quiet-cpu-cooler/#findComment-4831892
Also between both please help
It seems you're either upgrading or planning a new system. In that case, please read before posting: http://linustechtips.com/main/topic/3061-build-plan-thread-recommendations-please-read-before-posting/
and post a single thread to the New Builds and Planning sub-forum instead of making several threads that are all somewhat incomplete.
https://linustechtips.com/topic/355939-quiet-cpu-cooler/#findComment-4831917
I see what you are saying but all I need help with is case and cpu cooler so it kinda seemed like these forums would be better help I guess not?
<p>Wish I could have this already!! : http://pcpartpicker.com/p/qTLRjX
https://linustechtips.com/topic/355939-quiet-cpu-cooler/#findComment-4831926
What cooler is recommended may depend on the case's clearance for it and vice versa..
https://linustechtips.com/topic/355939-quiet-cpu-cooler/#findComment-4831943
Will you still help?
you might want to conside a liquid cooling AIO if there might be clearance issues. By that, you outsource the heatsink to somewhere else in the case with enough space.
An additional quiet fan for the AIO would be good though.
The bequiet Shadow Rock 2 (or Slim) would also be relativeley low coolers with good cooling capacities. Bequiet also has a top flow cooler, don't remember what it's called.
who cares...
https://linustechtips.com/topic/355939-quiet-cpu-cooler/#findComment-4832064
look on my profile go to a new thread u sarted is it is more specific and shows 3 cases I liked also asked for water cooling there
https://linustechtips.com/topic/355939-quiet-cpu-cooler/#findComment-4832071
