Cases are inherently silent--the fans are what make it loud or quiet.
How small of a case are you looking for? Please list the components you plan to put inside, where you're shopping/located, and your budget.
https://linustechtips.com/topic/355935-downsize-help/#findComment-4831845
So I would like for a decent and quiet cpu cooler to be put in and a MSI 970 which is a big card so that is about all other than a wifi card
<p>Wish I could have this already!! : http://pcpartpicker.com/p/qTLRjX
https://linustechtips.com/topic/355935-downsize-help/#findComment-4831864
So my budget is up to $90 and and I will shop anywhere on pcpartpicker
https://linustechtips.com/topic/355935-downsize-help/#findComment-4831869
What kind of dollars are you using?
Rest of specs?
https://linustechtips.com/topic/355935-downsize-help/#findComment-4831883
Usd and eventually I want a i7 4790 a nice h97 mobo and this new case too
S340? https://store.nzxt.com/products/s340-black-red
It's a mid tower but sized similarly to some matx cases.
https://linustechtips.com/topic/355935-downsize-help/#findComment-4831908
Thank you also I am really just looking for a smaller more portable option than most standard atx so if that fives anymore insight as to a better case just throw it put regardless of budget
https://linustechtips.com/topic/355935-downsize-help/#findComment-4831915
I'd refer you to the below post ↓
It seems you're either upgrading or planning a new system. In that case, please read before posting: http://linustechtips.com/main/topic/3061-build-plan-thread-recommendations-please-read-before-posting/
and post a single thread to the New Builds and Planning sub-forum instead of making several threads that are all somewhat incomplete.
https://linustechtips.com/topic/355935-downsize-help/#findComment-4831928
