Best air filter?
Solved by WoodenMarker,
Happy to - front intakes are 3x Noiseblocker eLoops B12-3 running at full speed, exhaust is the stock case NZXT fan, undervolted to 7V and on top are two fans from the Kraken X61, also spinning @900RPM at idle... this should be positive pressure, but still dust gets inside
that is why I am looking for a fine filter
2x 140mm's + 120mm > 3x 120mm's.
It seems like you have negative airflow and not positive. I'd suggest getting a single magnetic dust filter for the rear and flipping that fan to intake.
