Ipod Nano 3rd gen problem
Go to solution Solved by Tedster,
I used to love the 3rd gen nano. Sounds like the battery's dead. Have you tried charging it for an extended period of time?
Otherwise try to boot into recovery mode and try the diagnostics:
So I got this old 3rd gen Ipod nano. 8GB black. The problem is that it beeps twice and then stays on a white blank screen. I took it apart already and its still doing the same thing. Is it fixable ? or do I need to access some special menu?
NEVER GIVE UP. NEVER STOP LEARNING. DONT LET THE PAST HURT YOU. YOU CAN DOOOOO IT
https://linustechtips.com/topic/355864-ipod-nano-3rd-gen-problem/
