So Guys, I have been wanting to do YouTube stuff for the past two years.
But i feel like my PC isn't really capable of recording games very well, I'm kinda looking for an upgrade but i don't know what to upgrade tbh, My budget is around 300-400 Euros
Now i have these specs:
CPU: AMD FX-4100
GPU: AMD Radeon HD6870
HDD: 500GB Seagate Barracuda
PSU: 600W Huntkey APFC 600
MOBO: MSI 760GM-p23
I don't need any accesoires or anything.
Edited by JustJollyJonah
Master of them Pokémon!
https://linustechtips.com/topic/35550-upgrade-advice/
Where are you shopping from?
https://linustechtips.com/topic/35550-upgrade-advice/#findComment-456223
Without knowing too much, my recommendations would be:
Get a new psu. Something like a cx500 should do.
Upgrade you gpu to a 7850 or 7870.
Get an ssd like a samsung 840 120GB for a primary drive and/or get a dedicated hard drive for recording.
The two possible problems I can think of are either your hdd is slow and that having a dedicated hdd to record to should help (in this case, getting an ssd should free up your current hdd as the dedicated recording drive), or that your gpu is too weak in general.
https://linustechtips.com/topic/35550-upgrade-advice/#findComment-457222
CPU: AMD FX-4100
HDD: 500GB
PSU: 550W Some random Brand
MOBO: MSI 760GM-p23
Is Italy close to you or is it Germany so I can us pcpartspicker  to help you with your build
https://linustechtips.com/topic/35550-upgrade-advice/#findComment-457323
I live in the netherlands, so germany would be alright i think ( sorry i'm a complete nube at this)
I searched high and low on the pc info highway to get you the best build on budget of 400 euros but alas I went 25.35 over budget because you forgot to add in memory & a case Sorry me lad I had to forgo the video card but don't be discouraged because it has onboard graphics as a Radeon hd 7000 graphics card here is my suggestion & videos for your build    http://de.pcpartpicker.com/p/1gAzO
http://www.youtube.com/watch?feature=player_detailpage&v=0nuXG1Ycjjs
http://www.youtube.com/watch?feature=player_detailpage&v=LpKaxg-m7_k
http://www.youtube.com/watch?feature=player_detailpage&v=Up7BJPyu3YA
https://linustechtips.com/topic/35550-upgrade-advice/#findComment-459084
Lawl i meant UPGRADE-Advice i already have a Case and memory and a motherboard and processor i just need advice on what to upgrade a new Video card or Processor
I am so sorry for the miscommunication but as a fellow techie specs is usually a piece of data and doesn't state to having the parts, I  will suggest you  update that part of your explanation to ( these are the parts I already have ) and let us start a new line of attack
https://linustechtips.com/topic/35550-upgrade-advice/#findComment-461645
It says in the First post on this thread:
CPU: AMD FX-4100
MOBO: MSI 760GM-p23
https://linustechtips.com/topic/35550-upgrade-advice/#findComment-461749
Ok guys, What should i do?
A; Spend all my money on A GTX770
B: Buy a HD7870 xt and New PSU and (maybe) later an SSD
For a 770, you'd want a new psu anyway.
Get a 7850/7870, a new psu, and a new ssd/cpu. Since you want to do Youtube stuff, you'll want more than 2 cores to makes videos. It's doable though.
https://linustechtips.com/topic/35550-upgrade-advice/#findComment-463025
