so i have a problem with my Razer Naga 2014
when i move the mouse quickly it works like it used to but when i move the mouse slowly(to the right or leaft) the cursor keeps jumping(to the right) a bit and it makes so i cant click on the correct thing so its terribly annoying and im afraid that i wont be able to use my mouse ever again but i really love this mouse
Things i tried so far :
Recalibrating the mouse to the mouse pad
plugging the mouse in a different usb slot
cleaning the connector
messing around with the settings in Synapse
blowing canned air around the sensor (used to help tracking isues)
cleaning the mousepad and the desk
Mobo - Asus Maximus VI Formula Ram - Kingston HyperX Fury 1866mhz CL10 16GBCPU - Intel i7 4790K ;
GPU - Gainward RTX 2070 Phantom ; PSU - Corsair RM750x Cooler - CM Hyper 212 EVO
https://linustechtips.com/topic/355299-razer-naga-2014-problem/
I would just return it to Razer.
An AMD cpu has no place in a solely gaming build, end of.
I3 4150, Intel HD graphics, corsair CX750M, 4gb ram, Asus H81M-E, corsair 230T, Intel stock cooler WD Green 2TB Gigabyte 550TI
Why you shouldn't trust Gpu or Cpu boss Click on this I dare you!
https://linustechtips.com/topic/355299-razer-naga-2014-problem/#findComment-4824715
i might bring it back to the store i bought it from ...
https://linustechtips.com/topic/355299-razer-naga-2014-problem/#findComment-4824792
Yes I would do that.
https://linustechtips.com/topic/355299-razer-naga-2014-problem/#findComment-4824805
uhmm.... somehow it seems to have fixed itself .... O_O
https://linustechtips.com/topic/355299-razer-naga-2014-problem/#findComment-4826896
Well if some how it breaks it self again then I would go and return it.
https://linustechtips.com/topic/355299-razer-naga-2014-problem/#findComment-4827236
