Outake Exhaust Help
Solved by ChaseB,
Oh, get a SP fan for that, the one I mentioned earlier. Use SP for any radiator.
SP fans are for pushing air through tight fin arrays like those found on radiators.. AF is for moving large volume of air... Unless the fin array on the cooler is VERY tight then stick to AF.. same for case fans.
AF then. SP is great for pushing air through a radiator etc. AF is great for general case fans.
SPs go with your cooler, I think the NF-F12s bc they are static pressure (SP)
