I think i have pretty much finished planning out my system so if you guys could tell me what you think that would be great!
It is a workstation/gaming build and here are the parts:
i7 4790k
asus strix 970 gpu
asus z97 pro gaming motherboard
corsair vengence 2133mhz 16gb ram
fractal design R5 case
intel 730 ssd and wd black 1tb hdd
Seasonic SS-520FL2 fanless 520 watt power supply
asus pb238q monitor
4x 140mm cougar vortex fans
noctua NHU-14S heatsink
logitech g710 plus keyboard
roccat kava plus mouse
windows 8.1 64 bit
yeah there it is so if you guys could tell me what you think that would be great!
Thank you!
https://linustechtips.com/topic/354950-my-system/
sounds good to me! But if you wanted to ever upgrade in the future, it might be a good idea to get a more powerful power supply now, just so you have that extra space to upgrade or even overclock. But other than that it seems great to me!
best of luck :)
- ethan
https://linustechtips.com/topic/354950-my-system/#findComment-4821220
best of luck :)
- ethan
yeah thanks I really like that psu though and it is really annoying it dosen't come in a higher wattage and I am trying to make a pretty silent build as well in which the psu is perfect for.
Thank you!
https://linustechtips.com/topic/354950-my-system/#findComment-4821233
Change HDD to Seagate Barracuda 1TB
Change GPU to a 290x.
Get a higher watt PSU using the money you saved from the 290x and HDD.
But if you like silence, ignore the 290x and PSU change
Na stay with nvidia. It's better ;)
What's the difference between sea gate barracuda and western digital. Same thing
Bro your power supply is so low my god. U need 650-750W psu
https://linustechtips.com/topic/354950-my-system/#findComment-4823926
1. The 290x has full 4gb vram as advertised
2. Seagate is cheaper
3. Nope, the PSU is fine
Lets all ripperoni in pepperoni
https://linustechtips.com/topic/354950-my-system/#findComment-4825833
