Gigabyte GTX 979 G1 Gaming? is that a new model? never new NVIDIA made a 979 ( i'm Joking i know you meant 970)
Also you seem to have double posted, and you don't need a i7 4790k, just get a i5 4690 its cheaper and performs the same for gaming, only get a i7 4790K if say you also render video
"Life's too Short, Use Express Install" Express install subject to spying
                                        -Microsoft 2015
https://linustechtips.com/topic/354806-how-does-it-sound/#findComment-4819731
Sounds great! Just make sure, hell, it's not my build, but make it awesome aesthetically, too.
Get two or three monitors, a big desk, comfy peripherals, and a comfy chair.
|  Athlon 750K   |   EVGA GTX 750 Ti FTW  |  Acer Aspire E15 - i5 6200u, 940M  |
|  Sennheiser HD 518   |   FiiO E10K DAC and Amp  |
Moto G (1st Gen)
https://linustechtips.com/topic/354806-how-does-it-sound/#findComment-4819746
I7 4790k
ASUS Sabertooth Z97 Mark 1
Corsair Dominator Platinum 2X4 GB
Intel 730 240 GB
Corsair AX860i
WD Black 1TB
                                        -Microsoft 2015
https://linustechtips.com/topic/354806-how-does-it-sound/#findComment-4819793
I7 4790k
Intel 730 240 GB
Corsair AX860i
WD Black 1TB
If you already bought the parts you made the mistake of getting a 4790k a i5 4690K is cheaper and performs the same for gaming
                                        -Microsoft 2015
https://linustechtips.com/topic/354806-how-does-it-sound/#findComment-4819848
