I have three fans all 120mm and I want to know if I should install the final one as a intake, exhaust or not install it at all
Thanks,
-Will
Where is the last fan or the other 2, im gussing the rest a intakes? Itd it rear most fan i always install as exh.
https://linustechtips.com/topic/354718-3rd-fan/#findComment-4818997
It would help to list your specs.
https://linustechtips.com/topic/354718-3rd-fan/#findComment-4831323
