I haven't been here in a while and forgot to post it here
I got a wireless mouse NO that is NOT the problem since on my old pc there was 0 problems.
I have a m.o.u.s 9. And a lot of times the cursor lags like ♥♥♥♥ing hell. Like I'll move it and it will take like 3 seconds to catch up. I tried every usb port. 2-3.0. All drivers updated. I looked online and it said in msconfig you set your cores correctly it mite work it didn't. I changed the battery like 4 times. Generic and name brand.
Carried in games to. Not just desktop.
CPU: i9 19300k////GPU: RTX 4090////RAM: 64gb DDR5 5600mhz ////MOBO: Aorus z790 Elite////MONITORS: 3 LG 38" 3840x1600 WIDESCREEN MONITORS
https://linustechtips.com/topic/354251-bad-mouse-lag-problems/
Probably getting interference from somewhere. Move the receiver closer or elsewhere, try changing the channel if possible, etc.
how do you change the channel?
https://linustechtips.com/topic/354251-bad-mouse-lag-problems/#findComment-4813700
