I used GPUz and it said that my second card is running at PCI-E x1.
When I start the little stress test, it shows both running at x16.
My question is; Does the second card idle at x1 and that flip into
x16 when under load?
I believe this is a good question. I have drivers all installed.
Cards are in PCI-E slots 1 and 3 (Asus crosshair v formula)
Both cards have two six pin power connectors connected.
should I connect the 12v plug on top or the extra molex
connector for extra power? I have a Corsair HX850. I'm quite sure
I'm good on power.
Sig
https://linustechtips.com/topic/354004-pci-e-speed-questions/
