im looking to make a script that would..."Check" my internet. or maybe ping a location. and if it doesnt recieve an answer OR if a "request timed out" it would simply pop up a bubble telling me "Internet lost" id like it to do this every 5 seconds.
..........i dont even remotely know how i would even go about this. been reading quite abit and i still dont get it :/ help would be very much appriciated.
"1 shot 1 kill. or in my case 500 shots and a questionable death" ~ Carlos Hathcock + Ryouichi
"Because its windows... it just happens..." ~ G33k 4 L1F3
My Build....sorta. close enough http://pcpartpicker.com/p/YMG4mG
https://linustechtips.com/topic/353523-auto-hot-key-script-internet/
you can probably make a script that opens CMD and runs a ping test..but for it to pop up with a message you would actually have to write a program
curious why you even want to do this? surely the connection icon on the desktop will tell you if you are connected or not
You could just write a simple .bat script to open CMD and ping a website, if you can ping the website, your internet is working.
[CPU: AMD FX-6100 @3.3GHz ] [MoBo: Asrock 970 Extreme4] [GPU: Gigabyte 770 OC ] [RAM: 8GB] [sSD: 64gb for OS] [PSU: 550Watt Be Quiet!] [HDD: 1TB] [CPU cooler: Be Quiet! Shadow Rock Pro Sr1]  -Did i solve your question/problem? Please click 'Marked Solved'-
...now that i have itnernet back. goddamn comcast.
anyways. soooo i cant have a ahk script auto ping a website every say ohhh 5000 milliseconds. and if the request times out i cant get a notification?
and mostly why do i want this
well easily. my little internet notification. it NEVER changes. even when i havnt had internet for the past couple hours. its all > YUP STILL GOOD. them blazing speeds.
theres a program that does kinda what im asking...but the smallest alotted time is 60 seconds. which is kinda lame.
