Split Steam library?
Solved by DevilishBooster,
I'm having difficulty finding an answer in my searches....
Can a Steam library be split between two drives?
Open Steam, go to Settings, Downloads, click on Steam Library Folders at the top, then click on Add Steam Library, and tell it which drive you want the library on. Then whenever you install a game it will ask you where to install it and you can select the library you want.
