I'm looking for a Program to control the speed of my fans in my computer, i currently am using MSI Afterburner for my GPU fan and it works well.
But i want to know if there is a program that will boost Fan speed over 100% and/or be able to control the speed % while in-game with the customizable keys on my gaming mouse without minimizing the game becasue i have a overlay to monitor GPU temps while Gaming. along side the FPS overlay
Also in Afterburner i can only select core temps to display (core 0, 1, 2 ,3 ect) and Speedfan (not a overlay) shows CPU temp 35c,single cpu core temps ( Core0, 1, 2, 3 ect)  how do i get it to show in afterburner as a game overlay as actual CPU temp ( not singe core temps )
i have a Intel i7 4790
Thank you
"Life's too Short, Use Express Install" Express install subject to spying
                                        -Microsoft 2015
https://linustechtips.com/topic/352751-fan-control/
You can't boost fan speed over 100%.
Also, just asking, why do you care about your temps so much during gaming, it's not gonna overheat as long as you have decent cooling and you're not overclocking.
About those fancy fan control macros, I don't think there's a way inside of MSI Afterburner or Speedfan, so you're out of luck for that one.
That's not supposed to do that....
https://linustechtips.com/topic/352751-fan-control/#findComment-4794748
what about the CPU temp overlay, i can only select to display singe core temps when i want to display the actuall cpu temp?
i can display GPU temp, just not overall CPU temp
                                        -Microsoft 2015
https://linustechtips.com/topic/352751-fan-control/#findComment-4794781
Core temps are the actual CPU temp, just pick the core that runs the hottest and display just that one.
https://linustechtips.com/topic/352751-fan-control/#findComment-4794840
