Overclocking GPU Help
Go to solution Solved by terrytek,
I can only increase it 12mV in MSI Afterburner, is +12 too much?
Really, the most i would go is up by half a volt higher than what came stock. Any more and you risk an unstable card.
I'm not a total noob with overclocking, I've overclocked lots of CPUs with (varying) success.
However with GPU's I just don't have much success.
Could you give me any tips?
  • Does increasing voltage increase stability?
  • Is the performance gain even worth it?
  • How far can you overclock your memory?
I have a ASUS GTX770 DCUII, which I got from a friend as a thank you gift for some favour.
I just want to see how far I can overclock it.
Cheers!
That's not supposed to do that....
https://linustechtips.com/topic/352737-overclocking-gpu-help/
1. It sometimes can, but push it too far, and you risk crashing your card.
2. Some cases, yes, but not all.
3. Really, as far as you dare.
https://linustechtips.com/topic/352737-overclocking-gpu-help/#findComment-4794535
https://linustechtips.com/topic/352737-overclocking-gpu-help/#findComment-4794572
