NZXT H440 Question
Go to solution Solved by airdeano,
yes, since you are not water cooling, two intake and two exhaust is fine, but
you'll notice a bit of an interior dusting issue as the 2x2 is a negative pressure
situation.
the three normal intake and one 140 exhaust is slightly positive, due to the filter
does reduce the amount of air incomming into the chassis.
only white  HSF i know of is the phanteks ph-tc14pe
i had to mod my nh-d14 to white:
Hi, so I ordered a NZXT H440 and should be arriving fairly soon, so it comes with 4 fans, 3 x 120mm in the front and a 1 x 140mm in the rear. The case supports a radiator upto 360mm and fans 120 and 140mm but I was wondering whether I can just attach two fans to the top of inside the case pushing air downwards instead of having a radiator? Thanks.
Also what would be the best looking white air cooler with good temps close or better than the Hyper 212 Evo, thanks. (Budget is about £25-30)
https://linustechtips.com/topic/352559-nzxt-h440-question/
situation.
https://linustechtips.com/topic/352559-nzxt-h440-question/#findComment-4793248
