1. Budget & Location
My budget is $1000 USD
2. Aim
The aim is to have portable LAN gaming machine that is able to run all major release games at 1440p resolution.
3. Monitors
Already have a 1440p monitor
4. Peripherals
Do not need any. Already have a copy of windows,.
I also have a 650W 80+ gold EVGA PSU in an atx form factor. I really like the design of the corsair 380t but I am open to other configurations as well.
Thanks!
https://linustechtips.com/topic/351987-1000-lan-rig/
Is the display included in the budget or do you already have it?
https://linustechtips.com/topic/351987-1000-lan-rig/#findComment-4785473
if you need the monitor:
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($177.99 @ SuperBiiz)
Motherboard: ASRock H97 PRO4 ATX LGA1150 Motherboard  ($83.89 @ OutletPC)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE 3X Video Card  ($314.99 @ Amazon)
Case: Cooler Master HAF XB EVO ATX Desktop Case  ($89.99 @ NCIX US)
Monitor: Acer G257HU smidpx 60Hz 25.0" Monitor  ($279.99 @ Newegg)
Total: $1044.84
Generated by PCPartPicker 2015-04-20 18:12 EDT-0400
If  u dont:
Video Card: EVGA GeForce GTX 980 4GB Superclocked Video Card  ($513.75 @ Amazon)
Total: $963.61
Generated by PCPartPicker 2015-04-20 18:13 EDT-0400
just use the psu you have.
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
https://linustechtips.com/topic/351987-1000-lan-rig/#findComment-4785499
Already have one.
How's this look? http://pcpartpicker.com/p/77tsCJ
https://linustechtips.com/topic/351987-1000-lan-rig/#findComment-4785537
Close to budget, stylish and good for 1440p
Motherboard: MSI H97I AC Mini ITX LGA1150 Motherboard  ($109.99 @ Newegg)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory  ($64.75 @ OutletPC)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($94.99 @ Amazon)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($49.30 @ Amazon)
Video Card: MSI GeForce GTX 970 4GB Twin Frozr V Video Card  ($339.99 @ SuperBiiz)
Case: Corsair 380T Mini ITX Tower Case  ($114.99 @ Micro Center)
Power Supply: XFX XTR 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($61.98 @ Newegg)
Total: $1013.98
Generated by PCPartPicker 2015-04-20 18:22 EDT-0400
CPU i5-4690K(OC to 4.4Ghz) CPU Cooler NZXT Kraken x41 Motherboard MSI Z97 Gaming 5 Memory G.Skillz Ripjaws X 16gb 2133 Video Card MSI GTX 1080 Gaming X           Case NZXT H440 Power Supply XFX XTR 750W Modular Storage Samsung 840 EVO 250gb/Seagate Barracuda 2TB Monitor Acer XB270HU G-Sync http://pcpartpicker.com/b/3CkTwP
https://linustechtips.com/topic/351987-1000-lan-rig/#findComment-4785561
2. Aim
3. Monitors
4. Peripherals
Thanks!
Well, here. This should be a pretty killer machine, you won't do much better than this.
Some would argue about my CPU choice, but I find it worth over the overclocking.
Motherboard: MSI H81I Mini ITX LGA1150 Motherboard  ($62.99 @ Directron)
Video Card: Gigabyte GeForce GTX 970 4GB Video Card  ($329.99 @ Amazon)
Case: BitFenix Prodigy (White) Mini ITX Tower Case  ($77.99 @ SuperBiiz)
Total: $968.89
Generated by PCPartPicker 2015-04-20 18:23 EDT-0400
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/351987-1000-lan-rig/#findComment-4785592
Total: $1013.98
I like it! Only problem is i dont need a power supply but thats not a big deal.
https://linustechtips.com/topic/351987-1000-lan-rig/#findComment-4785595
Its ok I don't like the 4440 processor because I have seen it bottleneck the 970 on my friend's computer.
In what did it bottleneck the 970..? (because it shouldn't)
https://linustechtips.com/topic/351987-1000-lan-rig/#findComment-4785596
Not sure what you mean..But I have seen bottleneck the 970 even EVGA told us it was a processor issue.
Can you specify what the situation was when the 4440 was bottlenecking the 970? It would also help to post the quote from EVGA.
https://linustechtips.com/topic/351987-1000-lan-rig/#findComment-4785616
It wasnt performing as well as it should on games like tomb raider, far cry 4, metro etc. I dont have the ticket because it was my friends.
https://linustechtips.com/topic/351987-1000-lan-rig/#findComment-4785625
The 4440 shouldn't have any issues with those games. It's more likely that was a driver issue or some other malfunction than a bottleneck caused by the cpu.
https://linustechtips.com/topic/351987-1000-lan-rig/#findComment-4785670
We tried troubleshooting all of that as well. Even through the 970 in my rig and it performed as expected.
https://linustechtips.com/topic/351987-1000-lan-rig/#findComment-4785698
Yeah.. that seems like some driver issues or the like.
https://linustechtips.com/topic/351987-1000-lan-rig/#findComment-4785703
Who knows. I just stay away from that cpu.
So... back on topic. Check my build.
https://linustechtips.com/topic/351987-1000-lan-rig/#findComment-4785733
If you don't need a power supply that gives you some wiggle room. Here you go, bumped you up to a i5-4690k, Z97 motherboard and aftermarket cooler. Now you can overclock too. B)
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($226.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper TX3 54.8 CFM Sleeve Bearing CPU Cooler  ($17.22 @ Amazon)
Motherboard: Gigabyte GA-Z97N-WIFI Mini ITX LGA1150 Motherboard  ($99.99 @ SuperBiiz)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($99.99 @ Amazon)
Total: $1013.22
Generated by PCPartPicker 2015-04-20 20:57 EDT-0400
https://linustechtips.com/topic/351987-1000-lan-rig/#findComment-4786535
