The molex conector may not be supplying enough power, you could have too much running of one power supply rail?
Desk: monitors 3x Asus VE248h(eyefinity), Keyboard Cm Strom Trigger(mx red), Mouse Corsair m65, Headset Audio Technica ATH-M50
Black Friday 2013 Build: i7 4770k, Gigabyte Z87X UD5H, 16gb Corsair, Msi R9 290, Corsair Axi 760, Corsair 750D, 2x intel 530 240gb ssd, 2x Seagate 400gb
Older Machine amd x640, msi 760g mobo, 8gb gskillz, Sapphire 6870, Corsair hx650, Cooler master haf 922, ocz agility 3 120gb ssd || HTPC: i7 3770k, shuttle xpc z77, 16gb gskillz, Asus GTX 650 ti, intel 120gb msata ssd
https://linustechtips.com/topic/35194-vga-connection/#findComment-450952
You should use the other 6 Pin PCI-E connector provided with your power supply (the one attached to the 8 pin already connected to your graphics card).
Sabot is probably right saying you're trying to pull to much power out of one rail.
https://linustechtips.com/topic/35194-vga-connection/#findComment-450988
