Gsync surround question
Solved by Glenwing,
If you enable surround they all need to be the same refresh rate, and G-SYNC won't work unless it's on all three. If you run surround with triple G-SYNC monitors you can get 3x 780 Ti's and connect one monitor to each DP output (according to NVIDIA's website anyway).
http://www.geforce.com/whats-new/guides/how-to-correctly-configure-geforce-gtx-680-surround#4
