I have bought
dell optiplex 9020 mt
Processor Intel® Core™ i7-4790 CPU @ 3.60GHz, 3601 Mhz, 4 Core(s), 8 Logical Processor(s)
RAM: 4 GB
i am adding another 4 GB of RAM
and i want a video card, i am not a gamer
i am a civil engineer student
I am running
1. photoshop cc
2. adobe premiere pro
3. AutoCad
but i feel that my Pc is little bit struggling  + I need a HDMI port
but i dont want to change my power supply
thank you everyone
https://linustechtips.com/topic/351611-help-in-choosing-graphics-card/
the GTX750Ti if the PSU is crap
or the R9 280 will be a good GPU if the PSU is decent
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
from Dell website they say that i have a 290w power supply
:o  :o  :o
ok look for a 750Ti without the PCI-E plug requirement
you are absolutely right
but i have no experience at all
i want something that fits my needs
I mostly use photoshop, unless you're working with super high resolution images, a 750ti should do the job. Though some things might take longer to load. Or you could look at quadro cards if you want 10-bit color stuff.
Fractal Design Define R4 | MSI x79a-GD45 | 3960X @ 4.6Ghz | Lots of EK Blocks | EVGA GTX780Ti 3GB | Corsair Dominator Platinum 16GB (4x4) DDR3 1866 | Samsung 840 Pro 512GB SSD | Western Digital Red 2TB x4 (Raid 10) | Corsair AX760 | Windows 7 Professional 64-bit
290w is it crap or decent  :lol:
total crap
I'd suggest GTX 750Ti, it's cheap but performs very well + power efficient (doesn't need power cable).
Where I hang out: The Garage - Car Enthusiast Club
My cars: 2006 Mazda RX-8 (MT) | 2014 Mazda 6 (AT) | 2009 Honda Jazz (AT)
PC Specs
Indonesia
CPU: i5-4690 | Motherboard: MSI B85-G43 | Memory: Corsair Vengeance 2x4GB | Power Supply: Corsair CX500 | Video Card: MSI GTX 970
Storage: Kingston V300 120GB & WD Blue 1TB | Network Card: ASUS PCE-AC56 | Peripherals: Microsoft Wired 600 & Logitech G29 + Shifter
Australia
CPU: Ryzen 3 2200G | Motherboard: MSI - B450 Tomahawk | Memory: Mushkin - 8GB (1 x 8GB) | Storage: Mushkin 250GB & Western Digital - Caviar Blue 1TB
Video Card: GIGABYTE - RX 580 8GB | Case: Corsair - 100R ATX Mid Tower | Power Supply: Avolv 550W 80+ Gold
so if bought EVGA GTX 750Ti i dont need to change the power supply
this one
http://www.amazon.com/EVGA-GeForce-750Ti-GDDR5-Graphics/dp/B00IDG3IDO/ref=sr_1_1?s=electronics&ie=UTF8&qid=1429527139&sr=1-1&keywords=EVGA+GTX+750Ti
What's your PSU? Well you don't have to, it needs very low power (60W).
PC Specs
Indonesia
Australia
What's your PSU? Well you don't have to, it needs very low power.
the Dell shitty OEM 290W PSU
290W????
PC Specs
Indonesia
Australia
290W????
yea thats Dell Pre-builds for you
Daaaaamn
PC Specs
Indonesia
Australia
:D  :D  :D
Is it that bad
290 was enough with the Pentium 4 rig
but in this year and age to see a 290 Watt PSU is like wow wtfbbq
Look at specs of the computer. A 290w is plenty to run that system in default configuration. There was no need for dell to put in any higher wattage. Hell, they could have put in a 250w psu and it would have still ran fine.
