https://linustechtips.com/topic/351531-cpu-cooler/#findComment-4779502
Apparently the 212 Evo hits the side panel window in that case. It fits but expect scratches or worse.
CPU: Intel i5-4690k                                                               RAM: 16gb Corsair Vengance Pro DDR3-2400        Case: NZXT S340
Cooler: CM Hyper 212 Evo                                                  Storage: Intel 730 SSD        PSU: EVGA 850G2
Mobo: Asus Z97-A 3.1                                                          GPU: 980ti G1        OS: Windows 10 Pro
https://linustechtips.com/topic/351531-cpu-cooler/#findComment-4779518
I want a cpu cooler and I was thinking about the Hyper 212 evo but it is to tall for my case the corsair spec 01. Does anyone have any recommendations for a cpu cooler under 150mm?
Here is my build.
http://pcpartpicker.com/p/6JB7qs
My budget is around $25
Thanks
http://pcpartpicker.com/part/cooler-master-cpu-cooler-rr910htx3g1
The CM Hyper 212 Evo will fit, but apparently the side panel window will hit the copper heat pipe tips and could cause damage.
https://linustechtips.com/topic/351531-cpu-cooler/#findComment-4779527
Oh, my bad. I assumed the case had ~159mm clearance.
In that case, I'd suggest a H7: http://pcpartpicker.com/part/cryorig-cpu-cooler-h7
https://linustechtips.com/topic/351531-cpu-cooler/#findComment-4779528
