New PC! Need Help!
Go to solution Solved by SImoHayha,
So, new PC is built, and is put together. I started it, and it posted. So i continue and install my OS. When it is finished i decided it is time to overclock, first the GPU, i download MSI afterburner, and msi afterburner gives me the error code 23.If anyone knows what this is please help me out :).     Meanwhile, I overclocked the CPU Succesfully to 3.5 ghz!  B)
Thanks, Coos724.
Try this
Go to your MSI Afterburner install folder and open up MSIAfterburner.cfg with Notepad. Find StartupViaTaskScheduler = 1 and change the 1 to 0 and click save. Restart MSI Afterburner.
Thanks, Coos724.
https://linustechtips.com/topic/351462-new-pc-need-help/
use precision X
https://linustechtips.com/topic/351462-new-pc-need-help/#findComment-4778609
Thanks, Coos724.
Try this
NEVER GIVE UP. NEVER STOP LEARNING. DONT LET THE PAST HURT YOU. YOU CAN DOOOOO IT
https://linustechtips.com/topic/351462-new-pc-need-help/#findComment-4778642
