which header of the mobo exactly?
does the mobo BIOS detect that fan?
try swapping the head to another header
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/350714-case-fan-not-working/#findComment-4779667
  • 2 weeks later...
