Had made a similar topic a while back, maybe you find something you like there:
http://linustechtips.com/main/topic/20417-best-wlan-n-adapter/
Christopher Kruse | Webdeveloper (Interface & Applications)
i7 3770k (3233C Batch) @ 4.2ghz | Asus P8Z77 WS | Gigabyte 780 Ti OC  | Corsair Vengeance LP 1600 32GB DDR3 | Samsung 850 EVO 500GB +2x Samsung 840 EVO 250GB + Samsung 830 256GB + 4x WD30EFRX, 2x WD30EZRX, 1xWD20EARS | Corsair AX750 + Bitfenix Extensions | Fractal Design Define XL R2 + Xigmatec 3in3 Hotswap Cage | Noctua NH-D15 + Thermal Grizzly Kryonaut, 5x Noctua NF-P14s redux-1500 PWM | Peripherals: Logitech G502 + Corsair K70 RGB + Red 40A-L O-Rings | Sound: Denon AVR 2807 via HDMI + 2x Nubert nuPro A-20 + 1x B&W CC6 Center | SoundMagic E10 | Jabra Speak 410
https://linustechtips.com/topic/35034-wireless-wifi-adapter/#findComment-448589
I went with this one in the end:
http://www.amazon.com/dp/B007GMPZ0A/
It's got 2x 450mbits while the other one only got 2x300mbits and the reviews on amazon are better
https://linustechtips.com/topic/35034-wireless-wifi-adapter/#findComment-448633
