Please power down and connect the pcie power cable(s) for this graphic card
it's my first build and it appear when i start my computer
what is this mean???
i got rosewill green 630W
one ssd
4670k
and 4gbx2 ram
how do fix it???   when i run without graphic card, it runs fine
https://linustechtips.com/topic/34986-power-down-graphic-card/
did u plug in the graphics card?
https://linustechtips.com/topic/34986-power-down-graphic-card/#findComment-447978
The power plugs are all the way in and fully clipped on?
https://linustechtips.com/topic/34986-power-down-graphic-card/#findComment-448004
Do you have another computer to try the card in?
https://linustechtips.com/topic/34986-power-down-graphic-card/#findComment-448021
is the other end of the cables plugged into the power supply properly?
It's non-modular.
https://linustechtips.com/topic/34986-power-down-graphic-card/#findComment-448032
Try a different slot if you can.
https://linustechtips.com/topic/34986-power-down-graphic-card/#findComment-448068
What were you using before this card? Just integrated or another discrete card?
https://linustechtips.com/topic/34986-power-down-graphic-card/#findComment-448119
its my first desktop i just built like 6 hours ago
when i run without graphic card it runs fine so it must be graphic card, right?
My bad. And, you can try RMA'ing the card. It's a little subjective as we can't perform other tests currently since you don't have any other hardware to use in the slot.
https://linustechtips.com/topic/34986-power-down-graphic-card/#findComment-448128
RMA stands for Return Merchandise Authorization. It either means you returned the product, or you are getting a replacement.
https://linustechtips.com/topic/34986-power-down-graphic-card/#findComment-448135
whats that?? like refund?? i bought it from superbiiz
Bad luck bro.. Contact with them, open a RMA, and sent an e-mail too. They have a super bad costumer service and RMA department.
G.SKILL Ripjaws X Series 16GB (4 x 4GB) 2133 | AMD FX-8350 Vishera 4.0GHz CORSAIR Hydro Series H100i | OCZ Vector 256G |
Asus Crosshair V Formula-Z | SAPPHIRE Vapor-X Radeon HD 7970 GHz Edition
XFX 750W BEFX
https://linustechtips.com/topic/34986-power-down-graphic-card/#findComment-448383
yea.....
I wasn't trolling I was just asking to make sure
https://linustechtips.com/topic/34986-power-down-graphic-card/#findComment-448819
Don't have a different power supply you could try from someone do you? Isn't rosewill a low-end brand, so it might not have a strong enough 12v+ rail in that psu to power the video card up? (Though booting shouldn't require that much power, could be defective psu though?).
https://linustechtips.com/topic/34986-power-down-graphic-card/#findComment-448925
Rosewill don't actually make any PSUs. Their power supplies are actually solid.
https://linustechtips.com/topic/34986-power-down-graphic-card/#findComment-448932
