I have a PS3 controller that I was hoping to use on my PC (for games like Borderland 2 on Steam) but I have looked at tutorials and I see there are 2 ways to set it up. They are Motionjoy (which apparently is horrible) and SCP which makes the game see all the buttons as if they are Xbox 360 buttons. Is there any way that I can make Borderlands display the PS3 buttons rather than the A, B, X and Y of the 360 controller?
AMD FX-6300 3.5 Ghz | Arctic Freezer A11 CPU Cooler | (4x4GB) 16 GB Hyper X Fury DDR3 1866 Mhz | Asus M5A97 LE R2.0 Motherboard | EVGA GeForce GTX 970 Superclocked ACX 2.0 | Rosewill Glacier 500W PSU | 120 GB Kingston SSD (Windows 7 Boot/Application Drive) | 250 GB Samsung 850 Evo SSD (Windows 10 Boot/Application Drive) | 1 TB Western Digital Blue (Storage Drive) | Bitfenix Neos | Windows 7 Pro 64-bit & Windows 10 Pro 64-bit
https://linustechtips.com/topic/349640-setting-up-ps3-controller/
in windows 8.1 it's a pain and you'll have to look into disabling driver sig enforcement. Install motionjoy drivers thru motionjoy, then use Better DS3 after plugging in your ps3 controller
Nude Fist 1: i5-4590-ASRock h97 Anniversary-16gb Samsung 1333mhz-MSI GTX 970-Corsair 300r-Seagate HDD(s)-EVGA SuperNOVA 750b2
Name comes from anagramed sticker for "TUF Inside" (A sticker that came with my original ASUS motherboard)
There was another way without motionjoy that was MUCH better than motionjoy, cant remember what it was but it was a thread on some website.
Project Cobalt:
CPU: AMD FX 8370 Motherboard:
Asus M5A97 R2.0
RAM: G.Skill Ares 16GB (2x8GB) DDR3 2133 GPU:
Gigabyte GTX 970 G1 Gaming Case: NZXT H440 (Blue)
Storage: Samsung 840 EVO 256GB +  2x 1TB WD Cavier Blue
PSU: Corsair 750G2
CPU Cooler: Swiftech H220X
Keyboard: Model M + a lot of others
Mouse: Logitech G502
Vintage Gaming PC: AMD Athlon T-Bird 800Mhz, Gainward nVidia Ti200 128MB, 512MB Crucial RAM DDR, Compaq ASPEN 2 OEM Board, Soundblaster Live! 5.1, Windows 98SE
I am using Windows 7 so I don't see how that has anything to do with 8.1 ... I was hoping to avoid Motionjoy if at all possible since I am hearing all of these horror storied about unremovable adware.
I tried that on Win 8.1 and it was a massive failure after hours of work and tons of shady, 3rd party programs. Just spend the $30USD and buy the 360 controller with the dongle, that what I wound up doing.
Unless you're a glutton for punishment....
END OF LINE
-- Project Deep Freeze Build Log --
Quote me so that I always know when you reply, feel free to snip if the quote is long. May your FPS be high and your temperatures low.
Well you need the drivers from motionjoy either way. Or you'll have to install them manually. Better DS3 is what you should use though. I use it but I needed the motionjoy driver, and I'm on 8.1 so installing it was annoying.
SCP driver is the best, I use it all the time. however YOU CANNOT change the X,Y,A,B buttons into Triangle, X, circle and Square. On a game as you would need to reprogram the game with different pictures or something like that in the game. Altho if you are using the SCP Driver with Far Cry 4 it won't load certain things and you need to uninstall it which takes roughly 30 seconds, with no reboot.
NEVER GIVE UP. NEVER STOP LEARNING. DONT LET THE PAST HURT YOU. YOU CAN DOOOOO IT
Does the SCP driver emulate the controller as a 360 controller?
yea I believe so...to be honest am not sure. It loads some drivers into the computer along with the addition 360 hardware add-on from Microsoft. In a sense trick the PC into thinking that the PS3 controller is a 360 one.
Yes, vibration and everything else work perfectly fine .... I just find the display of 360 controls silly when i am using a PS3 one (even if I am using software to allow me to use the PS3 controls) ... I mean Windows even installs the drivers and sees it as a PS3 controller as soon as you plug it in ... yet they don't support plug-and-play just because it isn't one of their devices?
SCP drivers are the best from my experience. Light-weight, no annoying windows or ads, and just worked. As for the icons on screen, they have to be programmed into the games, and most people use X360 style controllers on PC so they only include X360 icons. Some games like Final Fantasy XIV do support PS3 icons, though.
When I bought the adapter for my PC to use my xbox controller on my PC it felt like it was always a little bit behind from what I was pressing, I didn't really enjoy it to much.  Maybe I did something wrong though?
  • CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor Motherboard: ASRock Z97 Extreme3 ATX LGA1150 Motherboard Ram: Team Zeus Blue 16GB (4 x 4GB) DDR3-1600 Memory GPU: Asus GeForce GTX 970 4GB STRIX Video Card Case: Phanteks Enthoo Pro ATX Full Tower Case Storage: Crucial MX100 128GB 2.5" Solid State Drive, Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive PSU: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply Display(s): Asus VG248QE 144Hz 24.0" Monitor Cooling: Phanteks PH-TC12DX_BK 68.5 CFM CPU Cooler Keyboard:Corsair K70 RGB Cherry MX BrownMouse: Razer Deathadder Operating System: Microsoft Windows 8.1 (32/64-bit) PC Part Picker URL: http://pcpartpicker....aze101xx/saved/
No option of using a 360 or Xbox one controller? You just download the driver from Major Nelson's site or Microsoft's site and hook it up via USB.
I'm going to punch your face- IN THE FACE.
Not unless the wireless 360 controller can hook up via its USB play-and-charge cable (which it can't). I'm not spending $ for a wireless receiver for the 360 controller when the PS3 controller works fine via USB cable ... I'd be more willing to buy a micro bluetooth reciever for $10 for my PS3 controller than $35+ for the 360's wireless receiver. To be brutally honest, the RB and LB on the 360 controller are a sad imitation of the R1 and L1 on the PS3 controller. At least that's my opinion on this ... But I asked for a way to change the buttons displayed in-game ... not to be asked why I don't just use a 360 controller.
Ouch. Well I guess everyone has their own opinion. I personally like having a simple wired connection to my Xbox one controller. I've tried it before and it seems just fine. I disagree with you on the imitation part. As much as I love Playstation products, their controller was just way too small and uncomfortable to me. I do not even have big hands and it felt too small. The 360 and Xbox One controllers are literally the most comfortable controllers I have ever experienced with their finely made grips and anti-sweat materials. The PS4 controller is leaps and bounds better than the PS3 controller though, and I say it is on par with the X one controller.
