Ok some background first I have been trying to build this thing for 3 months now and I need to stop and finalize this damned build.  General knowledge for the build as follows.
<Feel free to make suggestions>
Use: YouTube and Twitch.tv Streaming as well as video editing
Budget: Don't just read the number and build I need you to actually modify my build because it has custom parts      <---       READ           2200USD
Link: http://pcpartpicker.com/p/zmNvkL
Other stuff: Feel free to suggest stuff other than listed if you have knowhow on YouTube
Thanks!
https://linustechtips.com/topic/349366-ready-to-order-please-help/
Looks good to me to be honest, there's nothing obvious that I would change. I do want you to know that a 970 is unlikely to push 120+ fps on high to ultra settings if you want to play modern games. So I would either get two 970s, or get a cheaper monitor with a 60hz refresh rate and maybe consider going for surround at 60hz. If instead you play stuff that isn't very demanding like cs:go then you're perfectly fine.
sudo chmod -R 000 /*
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor  ($239.99 @ SuperBiiz)
Motherboard: Gigabyte GA-H97M-D3H Micro ATX LGA1150 Motherboard  ($83.99 @ SuperBiiz)
Video Card: Sapphire Radeon R9 290 4GB Tri-X OC Video Card (2-Way CrossFire)  ($239.99 @ Newegg)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit)  ($91.75 @ OutletPC)
Monitor: Asus VG248QE 144Hz 24.0" Monitor  ($249.99 @ Micro Center)
Monitor: Asus VX248H 60Hz 24.0" Monitor  ($169.99 @ Best Buy)
Keyboard: Corsair K70 RGB Wired Gaming Keyboard  ($155.49 @ Amazon)
Mouse: Razer DeathAdder Chroma Wired Optical Mouse  ($54.99 @ Amazon)
Other: SteelSeries QcK Gaming Mouse Pad (Black) ($8.40)
Other: Audio-Technica AT20USB Cardioid Condenser USB Microphone ($109.00)
Other: Dragonpad pop filter® Studio Microphone Mic Wind Screen Pop Filter Swivel Mount 360 Flexible Gooseneck Holder ($5.23)
Other: Neewer® Black Universal Microphone Shock Mount Holder Clip Anti Vibration Suspension High Isolation with for Studio Condenser Mic, Idea for Radio Broadcasting Studio, Voice-over Sound Studio and Recording ($10.50)
Other: NEEWER Microphone Suspension Boom Scissor Arm Stand ($15.95)
Total: $2102.20
Generated by PCPartPicker 2015-04-16 15:04 EDT-0400
Thanks!
Looks fine. You could save a few dollars by getting a WD Blue but otherwise it looks good.
For a streaming build it looks good enough. Depending on the games you play the 970 could be the weak point, as it's not going to allow for high end ultra gaming at 100+fps; but you can add another 970 later obviously.
For not so demanding stuff it's awesome.
Memory: G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-2133 Memory ($99.99 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive ($94.99 @ Amazon)
Storage: Western Digital BLACK SERIES 1TB 3.5" 7200RPM Internal Hard Drive ($66.99 @ Best Buy)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case ($89.99 @ Newegg)
Power Supply: EVGA SuperNOVA NEX 750W 80+ Gold Certified Fully-Modular ATX Power Supply ($74.99 @ NCIX US)
Total: $2102.20
% increase in performance ?
Rendering/Video/Steaming performance on gpu?
CPU changes gets rid of hyperthreading or no?
The cpu has hyper threading.
You dont NEED CUDA for video editing anymore , AMD cards do just fine actually.
I was reading an article on creative cow about that a few days ago.
So probs just going to save up for 980 then
Here you go, re-tooled your list to fit a 980 in the same budget. Dropped the mouse and keyboard for the Cooler Master Devastator bundle. I have it and it's solid for the price, your money is better spend on a video card than a $150 keyboard and $55 mouse. Also switched you out to an NZXT Kraken x41. Is an awesome cooler set up in push/pull on the exhaust and $20 cheaper.
You'd be blasting 1080p with this setup.
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($324.99 @ SuperBiiz)
CPU Cooler: NZXT Kraken X41 106.1 CFM Liquid CPU Cooler  ($96.97 @ Amazon)
Motherboard: MSI Z97-GAMING 5 ATX LGA1150 Motherboard  ($134.99 @ Amazon)
Video Card: MSI GeForce GTX 980 4GB Twin Frozr Video Card  ($549.99 @ Newegg)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($84.99 @ NCIX US)
Keyboard: Cooler Master CM Storm Devastator Gaming Bundle Wired Gaming Keyboard w/Optical Mouse  ($26.99 @ NCIX US)
Total: $2231.69
Generated by PCPartPicker 2015-04-16 15:57 EDT-0400
CPU i5-4690K(OC to 4.4Ghz) CPU Cooler NZXT Kraken x41 Motherboard MSI Z97 Gaming 5 Memory G.Skillz Ripjaws X 16gb 2133 Video Card MSI GTX 1080 Gaming X           Case NZXT H440 Power Supply XFX XTR 750W Modular Storage Samsung 840 EVO 250gb/Seagate Barracuda 2TB Monitor Acer XB270HU G-Sync http://pcpartpicker.com/b/3CkTwP
