I am hoping 2 build my first PC this summer, and i decided i wanted 2 have a watercooled system (custom loop) but i also wanted 2 stay on a budget ($100-250), and can any of u guys tell me if there a way 2 cool my system on that budget
My specs r:
Case-NZXT Phantom 410
Motherboard-MSI Z87-GD65
CPU-Intel Haswell i5-4670K
GPU-EVGA GeForce GTX 770
Cooler-Corsiar H100i-
RAM-CORSAIR Vengeance Pro 8GB (2 x 4GB)
SSD-SAMSUNG 840 250GB
HDD-WD Blue 0.5TB
PSU-SeaSonic SS-750KM3
Thnx in Advance  :D
https://linustechtips.com/topic/34902-watercooling-help/
i was wondering if u can get any cheaper
If course you can. You can pick any pump/res/waterblock/radiator but I don't think anyone could tell you with certainty that those components will work well, look reasonable, won't be loud or won't die after 1 or two years. And if you have to replace a pump after two years for example you might as well have gone with the more expensive one that will last double, triple or even more as well as getting better performance while using it.
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
https://linustechtips.com/topic/34902-watercooling-help/#findComment-451784
well i guess custom loops rnt for me, but so if i go with a AIO cooler, id probably go with a h100i, but they say a u can get a air cooler with much less noise and better preformance, is it true, if so which?
https://linustechtips.com/topic/34902-watercooling-help/#findComment-451813
I wouldn't say it performs better than the H100i for certain but the Noctua NH-D14 is a favorite.
I would make a thread in the air cooling section.
https://linustechtips.com/topic/34902-watercooling-help/#findComment-451843
