GPU for friend
Go to solution Solved by CalebTheEternal,
The 750ti would probably be good. Warthunder isn't a very intensive game. The 750ti is a good card. My old GTX 660 can play Battlefield 4 on high-ultra 1080p
I have a friend who enjoys playing war thunder, it is the only game he plays. He already has 8GB of ram and an i5-2500. Would a 750ti be good for playing war thunder at mid-high settings, or should he go for something better?
http://pcpartpicker.com/p/9DNjLk I like the night theme, it complements my dark basement. If you are reading this then you must also be a fan of the night theme.
01011011 01000010 01101001 01101110 01100001 01110010 01111001 00100000 01001000 01100101 01110010 01100101 01011101
https://linustechtips.com/topic/348917-gpu-for-friend/
CPU: Ryzen 5 5600 Motherboard: MSI B550 Tomahawk RAM: 32Gb DDR4  GPU(s): MSI 6800-XT Case: NZXT H440 Storage: 4x 250gb SSD + 2TB HDD PSU: Corsair RM850x with CableMod Displays: 1 x Asus ROG Swift And 3 x 24" 1080p Cooling: H100i Keyboard: Corsair K70 RGB Mouse: Corsair M65 RGB Sound: AKG 553 Operating System: Windows 10
Current PC:
http://i.imgur.com/ubYSO3f.jpg          http://i.imgur.com/xhpDcqd.jpg
https://linustechtips.com/topic/348917-gpu-for-friend/#findComment-4748541
What resolution?
Love cats and Linus. Check out linuscattips-fan-club. http://pcpartpicker.com/p/Z9QDVn and Asus ROG Swift. I love anime as well. Check out Heaven Society heaven-society. My own personal giveaway thread http://linustechtips.com/main/topic/387856-evga-geforce-gtx-970-giveaway-presented-by-grimneo/.
https://linustechtips.com/topic/348917-gpu-for-friend/#findComment-4748543
750ti would do, or the Radeon R9 270x 4GB for higher resolution.
Different PCPartPickers for different countries:
UK-----Italy----Canada-----Spain-----Germany-----Austrailia-----New Zealand-----'Murica-----France-----India
10 minutes ago, Stardar1 said:
Well, with an i7, GTX 1080, Full tower and flashy lights, it can obviously only be for one thing:
Solitaire.
https://linustechtips.com/topic/348917-gpu-for-friend/#findComment-4748550
If you're spending that much on an R9 270X 4GB though, it would be better to get an R9 280 3GB. 1GB less VRAM, but GPU-bound games (not as much VRAM, but GPU bound) will run better.
https://linustechtips.com/topic/348917-gpu-for-friend/#findComment-4748556
What resolution?
How do I check?
https://linustechtips.com/topic/348917-gpu-for-friend/#findComment-4748575
http://www.newegg.com/Product/Product.aspx?Item=N82E16814202049
$180 for the 4GB card, i was running with this for awhile and dabbled in war thunder a bit, i had 40 FPS low
Solitaire.
https://linustechtips.com/topic/348917-gpu-for-friend/#findComment-4748580
How do I check?
Assuming PC, right click desktop, click display, it will appear there.
Solitaire.
https://linustechtips.com/topic/348917-gpu-for-friend/#findComment-4748587
Or you know, could get a 280X for that price and will crush everything, I can't think of any benchmark the 280x would lose to that card. There's no way that card would use more than 3gb let alone 4gb unless you literally only play games like Shadow of Mordor. (edit: at 4k with 16x SSAA)
Current Desktop Build | 2200G | RX 580 4GB | 8GB RAM | CTRL | Logitech G Pro Wireless
Laptop | 2018 MBA 256/16GB | MX Master
https://linustechtips.com/topic/348917-gpu-for-friend/#findComment-4748599
I have not seen a 280x for $180, please enlighten me.
Solitaire.
https://linustechtips.com/topic/348917-gpu-for-friend/#findComment-4748612
What resolution?
1080p, his budget is at most $200, about $150 USD is the target area though.
https://linustechtips.com/topic/348917-gpu-for-friend/#findComment-4748616
R9 280s cost about as much, you can get R9 280Xes used (though I get why you wouldn't want to buy used) for less. Either will offer better performance at 1080p, especially since very few games use close to 4GB at 1080p.
https://linustechtips.com/topic/348917-gpu-for-friend/#findComment-4748632
there was a sale in which it hit 190$ a bit ago ($210 -20)
http://linustechtips.com/main/topic/311609-newegg-sapphire-vapor-x-r9-280x-3gb-190/
https://linustechtips.com/topic/348917-gpu-for-friend/#findComment-4748637
How about the r9 280. That is about $179 to $187 for Sapphire versions. Its a better card. http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&IsNodeId=1&N=600489223
http://www.anandtech.com/show/7764/the-nvidia-geforce-gtx-750-ti-and-gtx-750-review-maxwell/14 750ti
and
http://www.guru3d.com/articles_pages/his_radeon_r9_280_iceq_x2_review,16.html
https://linustechtips.com/topic/348917-gpu-for-friend/#findComment-4748705
