Ram running at under default speed.
Solved by 79 Potatoes,
That's the problem. That cpu only supports up to 1333 Mhz. I think that in non-z mbs it only allows up to 1400 Mhz (at least what I could set in a H81 mb when updating BIOS with a G3220)I'm using a pentium g3258. But I was using a z87 motherboard and I was able to run the ram at 1600mhz with the same cpu.
In Z series mb you can go beyond that limit because it's an overclocking platform
