I've always wondered if its possible to fuse the integrated graphics from an Intel CPU with a Nvidia Graphics Card, I've heard of AMD crossfire using the AMD CPU graphics to help the AMD GPU. Is is possible with Intel and Nvidia?? Why or Why not? (Just super curious)
Thanks for your time :)
https://linustechtips.com/topic/347478-integrated-graphics-and-graphics-card/
intel and nvidia are differnt brands. amd and amd are the same company so they make their low end gpus crossfire with the apu.
edit maybe with direct x12?
still wouldn't make sence
why penalize the cpu + ram if a gpu is installed
Wasnt there something called Lucid MVP around that didnt really take off that was to make use of both intergrated and dedicated?
Hey bro whatcha DOOOOOOOOIN *Barfs fruit salads on your chest*
i7 4820K / Sapphire Radeon HD 7970GHZ 6GB \ 16GB Corsair Vengeance (4X4) / Gigabyte X79-UD3 \ EVGA Supernova G2 850W / Windows 7 Ultimate / Dell U2412M \
Dat be spooky....my hella rad pootpoot *u*
