im going to start building "Black Glacier" soon its going to be a haf xb evo from cooler master with a full custom ekwb loop.
parts: https://www.komplett.no/k/shoplist.aspx?mode=receive&si=1476852&su=918A10D7-BF20-48F8-9BE8-7B24A223AC39
(post will get updated when all parts have arrived and layed out for assembly)
My pc:
http://pcpartpicker.com/p/dvcw23
(Black Glacier)
My server:
Dual xeon x5679 processors, 24gb of ECC memory, Nvidia quadro 295 NVS and 48tb of storage.  (z600
https://linustechtips.com/topic/347122-watercooled-lan-box/
I have the same case and am planning a custom loop (currently running the case on air). I have been advised, as I do not know much myself, that a 240 rad on its own wont be enough.
this is a link to my build http://linustechtips.com/main/topic/339645-new-watercooling-build-advice-needed/, to summarise though i plan to use a 280mm rad upfront, a 120mm rad in the rear and maybe a 160mm rad (2 x 80) in the bottom rear.
But I have since thought of maybe going to a higher fpi rad so that I can get more heat dissipation per rad installed.
The case will be cramped for a custom loop but if like me you just like the look of it im sure it will be worth it in the end.
https://linustechtips.com/topic/347122-watercooled-lan-box/#findComment-4726122
there wont be enough space for a 280mm rad (and for cpu only loop you wont need more than 240mm rad (tripple check clearance between your gpu and rad i have 1mm of clearing between them)
My pc:
(Black Glacier)
My server:
https://linustechtips.com/topic/347122-watercooled-lan-box/#findComment-4726137
Wouldn't be my choice of case if I wanted something remotely portable but whatever floats your boat.
I also wouldn't do a custom CPU loop since there is lots of good CPU-coolers and the greatest benefit with custom WC is getting better and quieter cooling for your GPU (Which really wouldn't hurt with a 290).
https://linustechtips.com/topic/347122-watercooled-lan-box/#findComment-4726931
i know but watercooling a xfx r9 290 is like crashing a ferarri to get a honda accord bechause the xfx coolers are so pretty.
My pc:
(Black Glacier)
My server:
https://linustechtips.com/topic/347122-watercooled-lan-box/#findComment-4726982
