help reguarding gpu thermal paste
Go to solution Solved by screamXrawr,
You'll need to replace it.
It should be replaced every time you remove the cooler, I personally like to use MX-4.
you are going to have to replace the factory thermal compound and you will have to be careful about the heat pads as well see this linus video.
https://www.youtube.com/watch?v=qDLQ7FjPMf8
Keep in mind this will most likely void your warranty.
ok then thanks for the help guys :D
I want to paint over part of my gpu shroud but in order to take off the shroud i have to take the entire cooler off of the pcb. Is it safe to leave the factory paste on there when I put it back together or should I replace it?
There is nothing wrong with temps but I dont know if its necessary to replace it as to not get air bubbles or anything like that.
What would you recommend?
The gpu is a r9 280x toxic
https://linustechtips.com/topic/346945-help-reguarding-gpu-thermal-paste/
