The BenQ XL2411 is a great choice. 1080p, 24 inch, 144hz, and only $250. Great choice for gaming and Linus said it had one of the best TN panels he has ever seen. Sadly FreeSync monitors are way out of your price range right now and aren't worth it.
CPU: Intel i5 4690k @ 4.3 GHz       GPU: MSI GTX 980                      Cooling: be quiet! Pure Rock                     OS: Windows 7            Monitor: BenQ XL2411Z
Motherboard: AsRock Z97 PRO4   PSU: Corsair 600W CX600M       Keyboard: Razer BlackWidow Ultimate   SSD: Intel 120GB 520   Headset: HyperX Cloud II
RAM: 12GB Crucial Ballistix            Case: Corsair 750D                       Mouse: Logitech G502                         HDD: Seagate 1TB        Speakers: Audioengine A5+
Maybe the asus VG248QE its 1ms and 144Hz, and you can buy it with a g-sync (more expensive though) but if you buy the standard verision first you can buy a g-sync module and add later on if im right
FX-8350 GTX760 16GB RAM 250GB SSD + 1TB HDD
"How many roads must a man walk down?" "42"
