I have gta 4 on steam and when I try to play it, it will ask me for my social club login and then I'll click play. When I click play is says I'm playing Grand Theft Auto 4 for about 2 seconds then it just puts me back into online. It doesn't give a crash message or anything.
CPU: some amd thing Motherboard: its black RAM: its memory thats for sure GPU: r7 260x Case: corsair spec 01 Storage: 1tb of it PSU: 430w, so many watts
Display: its asus Cooling: fans Keyboard: logitech g710+ #browns4lyfe Mouse: its a logitech Sound: its what you hear Operating System: winders
https://linustechtips.com/topic/346222-gta-4-will-not-open/
check the integrity of the game cache
English?
https://linustechtips.com/topic/346222-gta-4-will-not-open/#findComment-4714912
I blame GFWL
3 tips to have a good time on the LTT forums | 1. When you reply to someone please quote them | 2. Please follow your threads | 3. Follow the C.o.C
If you follow these 3 tips you should have a blast.
i'm rather proud of this for some reason. http://imgur.com/6ttS5XZ
https://linustechtips.com/topic/346222-gta-4-will-not-open/#findComment-4714915
English?
is this english?
蒸気でゲームに移動し、右のゲームをクリックして、ローカルファイルにアクセスし、ゲームCACHをチェック
but in all seriousness go to the game on steam and right click the game and go to local files and check the game cach
https://linustechtips.com/topic/346222-gta-4-will-not-open/#findComment-4714942
is this english?
I did that, it didn't help
https://linustechtips.com/topic/346222-gta-4-will-not-open/#findComment-4714950
What skin is that?
https://linustechtips.com/topic/346222-gta-4-will-not-open/#findComment-4714955
well you stumped me, launch the game from its directory to see if  that helps
Nope didn't work
https://linustechtips.com/topic/346222-gta-4-will-not-open/#findComment-4714985
well you stumped me
Well then
https://linustechtips.com/topic/346222-gta-4-will-not-open/#findComment-4714998
use xliveless. GTA 4 is pretty much broken without it.
http://gtaforums.com/topic/388658-relgtaiv-xliveless/
INTEL CORE I5 4670K | NVIDIA GTX 980 | NOCTUA NH-L9i | GIGABYTE GA-Z97X-SLI | KINGSTON 120GB V300
CM STORM QUICKFIRE TK | BENQ XL2420TE | ROCCAT SAVU | FRACTAL DEFINE R4
https://linustechtips.com/topic/346222-gta-4-will-not-open/#findComment-4715015
do this
https://support.rockstargames.com/hc/communities/public/questions/200548193-Why-won-t-GTA-IV-work-on-Windows-8-1
and if you have problems with getting your graphics settings working then do this
https://support.rockstargames.com/hc/en-us/articles/200145206-Issues-with-GTA-IV-showing-video-cards-with-over-2GB-as-under-spec
I literally just had to do this for myself after reinstalling the game.
https://linustechtips.com/topic/346222-gta-4-will-not-open/#findComment-4715046
