i just bought a g3258 and im wondering why the stock fan that came with it has a 2-3 second delay when booting then it full throttle at the start? is that normal? does intel set it like that now? i5 2500k dosent do that so im thinking its broken
thanks
its normal
I dont think it's an intel thing, just the motherboard manufacturer.
AAAAAAAAAGGGGGGGHHHHH!!!!
https://linustechtips.com/topic/345922-g3258-fan-delay/#findComment-4711048
thanks
This is how they all work for the most part. When first booting your computer is initializing all the devices and basically checking that it's all together, similar to you waking up in the morning. The fan goes to 100% as a failsafe to protect your processor if any part of the initialization fails. Once complete the fan is throttle based on CPU temperature.
1. Overclock until the magic smoke comes out. 2. Modify until broken. 3. Fix and repeat.
4670k - 16GB - 290X - 1440p Freesync
https://linustechtips.com/topic/345922-g3258-fan-delay/#findComment-4730368
