Partial Screen Size? Need Help!
Go to solution Solved by dragoon20005,
I have an R9 280X. How would I go about changing the scaling?
it will be under screen resolution
if not CCC should have the option too
Well, I apparently made a mistake by swapping out my shitty ASRock motherboard with an MSI SLI Plus Krait Edition. Now only part of my screen is being used up, leaving annoying black bars around my partial screen. However, if I lower the resolution to 1050p or 768p, the entire screen is once more used up, but I bought a decent 1080p monitor for a reason, so does anyone have any suggestions? I'm desperate here. Also, know that I already installed the latest drivers for both my motherboard and GPU, so that's not the cause.
CPU: i7 4790k @ 4.6 GHz Motherboard: MSI SLI Plus Krait Edition RAM: 16 GB (2x8) 1866 MHz Kingston Black Fury Series GPU: Gigabyte GTX 970 G1 Gaming Case: NZXT S340 (Black) Storage: Intel 730 Series SSD (240 GB), Seagate Barracuda (1 TB) Display: LG 24MP55 Cooling: Cooler Master Hyper 212 Plus Keyboard: Corsair K95 RGB for gaming (1st Player Fire Dancing for typing) Mouse: Logitech G502 Sound: Corsair Gaming 2100 Vengence 7.1 Headset Operating System: Windows 10
https://linustechtips.com/topic/344997-partial-screen-size-need-help/
Overscale thingy. What is your GPU? You just need to change in settings the scaling to 0% if I'm not wrong.
[CPU] i5-4690K @ 4.5GHz with NZXT Kraken X61 [MOBO] Asus Z97-AR [Memory] HyperX Fury 32GB DDR3-1600 [Storage] Samsung 840 EVO 500GB & WD 1TB Black & Hitachi 1TB [GPU] Gigabyte GTX 1080 8GB Xtreme Gaming [Case] Corsair Air 540 [PSU] Cooler Master V1000 [Case Fan] Corsair SP140 LED Fan x 3 & SP120 LED Fan x 3 [Display] Main: Philips 31.5" FULL HD IPS | Side: Philips 28" 4K UHD [Keyboard] Razer Blackwidow Ultimate Stealth Edition [Mouse] Razer Ouroboros [Mouse Pad] Razer Firefly [Sound] BOSE Companion 5 Multimedia Speaker System
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
Are you using the hdmi output on your gpu. If so go into catalyst control centre and screen/ display settings (cant remember). From there adjust over/ underscan accordingly.
i5 4670k / Be Quiet Dark Rock Pro 3 / Asus Maximus vi hero lga 1150 mobo / Sapphire tri-x r9 290 OC edition / corsair vengeance pro red 4 x 4 gb 2133mhz cas 9 ram kit / nzxt phantom 530 black / 120gb samsung 840 evo ssd / 240 gb ocz arc 100 ssd / 2x 1tb WD Blue / Cooler Master v850 modular psu / corsair k70 rgb cherry mx Brown / mad catz rat 5 laser mouse / windows 10
