Best price/performance PC fan?
Go to solution Solved by LegacyStijncat,
Well good price to performance fans, but not too loud.
  1. The Bol.Quiet fans don't even reach 20 decibels at 1600 RPM, so that should satisfy you.
  2. Your title say price/performance, which would mean getting cheap things. Your description asks for Leds AND silence, which ups the costs amazingly. Just doesn't make sense.
  3. Also, remember to follow your topic, top right corner of your screen!
I am looking for 2 quite fans with red LED's. What would you recommend?
01101110 01101111 00100000 01101111 01101110 01100101 00100000 01101100 01101111 01110110 01100101 01110011 00100000 01111001 01101111 01110101
Main Rig: i7-4790K | Corsair H100i | Asus Z97 | 16GB Ripjaws | 4TB WD Black/512GB SSD | x2 R9 290x | NZXT H440 | HX1000i | 6 Noctuas   [spoiler=SILENT BUILD] Silent build: i5-4460, Be Quiet! Pure Rock, Asrock H97, 8GB HyperX, Samsung 850 Evo 500gb, MSI GTX 970, Be Quiet! Silent Base 800, EVGA Supernova GS 650w
AMD CPU's. [spoiler=] thats right m8 get 420 no scoped
https://linustechtips.com/topic/344878-best-priceperformance-pc-fan/
Description doesn't line up with what you are asking for, but okay.
Heard lots of good things of Lepa's Bol.Quiet PWM fans, take a look at them.
Basic guide to CPU's!
If I said I were 14, you would call me a kid. If I say 70, you’ll entitle me too old. If I say 20 you say I’m inexperienced and if I say 40 than I'm too boring.
龴 ͡ↀ ◡ ͡ↀ龴#locked( ͡͡ ° ͜ ʖ ͡ °)
I have a pair of Red Corsair SP120's on the front of my case, and I love them!
Not horribly loud (compared to the Noctua 3k RPM fan in the back)
I usually have just them and the AF120's on unless I'm gaming or doing automated tasks in photoshop.
I said not too loud, and some fans offer good airflow, with led's, that's not too expensive, like the Corsair AF120.
not too loud
The Bol.Quiet PWM fans go to 8-18 Decibels. 18 decibels is at 1600 RPM.
The AF12 reaches 25,2 Decibels at 1500RPM.
Pretty sure Bol.Quiet will suffice.
Corsair AF120 Red, $20,95
Bol.Quiet PWM Red, $14,99
Corsair AF120: 3 pin
Bol.Quiet PWM: 4 pin, thus better fan control
Sweet. I'll get them. Thanks for the help!
No problem!
Here's the product pages for both the AF120 and the Bol.Quiet PWM. (Bol.Quiet even has more airflow somehow, looking at the specs).
If with this everything is solved, press the mark solved button the solution!
Lol, didn't know 18db was that quite
No problem!
yeah, already did. :)
Corsair AF120 Red Led, have 2 in my rig
Main Gaming PC (new): HP Omen 30L || i9 10850K || RTX 3070 || 512GB WD Blue NVME || 2TB HDD, 4TB HDD, 8TB HDD ||  750W P2 ||  16GB HyperX Black DDR4
Main Gaming PC (old, still own) : Intel Core i7 7700K @5.0Ghz || GPU: GTX 1080 Seahawk EK X || Motherboard: Maximus VIII Impact || Case: Fractal Design Define Nano S || RAM : 32GB Corsair Vengeance LPX
Cooling: EK XRES D5 100mm || Alphacool ST30 280mm w/ Vardars || Alphacool ST30 240mm w/ Vardars || Swiftech 3/8 x 1/2'' Lok-Seal Compressions || Swiftech EVGA Hydrocopper Block || Primochill Advanced LRT Orange || Distilled Water
Folding@Home Rig: 2x X5690s @4.6Ghz || GPUs: 2x Radeon HD 7990 || Motherboard: EVGA SR-2 || Case: Corsair 900D || RAM: 48GB Corsair Dominator GT 2000Mhz CL9
Ethereum Mining Rig: Pentium G4400 || Gigabyte Z170X-UD5 TH || 2x GTX 1060s (Samsung & Hynix) 1x GTX 1070 (Micron), 2x RX480s BIOS modded (Samsung), 1x R9 290X 8GB, 1x GTX 1660 Super = ~ 195 Mh/s
Peripherals: 3x U2412M (5760x1200), 1x U3011 (2560x1600) || Logitech G710 (Cherry Blues) || Logitech G600 || Brainwavz HM5 with @Gofspar Mod
Laptop: Dell XPS 15 || "Infinity Edge" 4K IPS Screen || i7 7700HQ || GTX 1050 || 16GB 2400Mhz RAM
