Need help with Clonezilla
Solved by Wadu436,
It worked with Clonezilla using these settings
If anyone else has this problem, here's a tip:
Clonezilla will copy the drive number too, so to enable your new drive, you've got to disable/rename your old one.
You can do this in the Disk Management (Start>>Right-click on Computer>>Manage>>Disk Management or else try googling "How to change the drive number in Windows (Your Windows Version Here)")
Then to enable your new one, again in Disk Management, right click on your new one, and select online.
