Hello people.
I have recently installed a new graphics card (r9 290x) and have also bought a new PSU (Antec true power 750w). However my computer can run games and everything completely fine however when I am on the desktop or doing tasks that are not intensive the computer will freeze and it will either restart or say that the display driver has stopped responding. When it restarts it turns back on and I get the error message attached to this text. I have no Idea what I need to do to fix this however if anyone could tell me it would bee much appreciated.
Crash.txt
Crash.txt
https://linustechtips.com/topic/344420-new-graphics-card-problems/
Hello people.
Crash.txt
your gpu is it 8 + 6 pin? If yes, are you using just 1 wire from psu to gpu to connect? If yes, try using 2 wire from psu to gpu. 1 wire connects the 8 pin and the other wire connects the 6 pin. At least this is what I did in the past and solved the issue.
[CPU] i5-4690K @ 4.5GHz with NZXT Kraken X61 [MOBO] Asus Z97-AR [Memory] HyperX Fury 32GB DDR3-1600 [Storage] Samsung 840 EVO 500GB & WD 1TB Black & Hitachi 1TB [GPU] Gigabyte GTX 1080 8GB Xtreme Gaming [Case] Corsair Air 540 [PSU] Cooler Master V1000 [Case Fan] Corsair SP140 LED Fan x 3 & SP120 LED Fan x 3 [Display] Main: Philips 31.5" FULL HD IPS | Side: Philips 28" 4K UHD [Keyboard] Razer Blackwidow Ultimate Stealth Edition [Mouse] Razer Ouroboros [Mouse Pad] Razer Firefly [Sound] BOSE Companion 5 Multimedia Speaker System
Hello thank you for your responses. I have not overclocked the card and I do have the 8 and 6 pins on different cables from my PSU.
when you install the GPU
did you use a fresh install of the GPU drivers?
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
I installed the GPU a few days ago.
I previously had an r9 270 in there which I used Uninstall a program in control panel and display driver uninstaller to remove the old drivers. I then put the new card in and installed the latest catalyst drivers. (14.12 Omega)
I fixed the display driver has stopped responding issue by this link however it still restarts:
http://www.computertipsfree.com/display-driver-stopped-responding-and-has-successfully-recovered-nvlddmkm-nvidia-atikmdag-ati-windows-7-vista-xp/
check your wiring for the GPU
