You don't need a Z97 board with that i3 chip as you can't overclock it.  Would recommend the Gigabyte GA-H97M-D3H or Asus Z87-A.
And yes, 500W is enough to power your system, but I would recommend EVGA 100-B1-0500-KR
You will save money with these recommendations too!
Case: HAF XBCPU: 4690kCPU Cooler: NH D15Motherboard: Gigabyte Gaming 7 | RAM: Hyper X FuryVideo Card: G1 Gaming 970SSD: 850 EVO |  PSU: Supernova 550 G2 |
https://linustechtips.com/topic/344339-first-build-need-a-psu/#findComment-4690474
Yeah that's a great idea if you're planning on going to an i7 or even the 4690k.  It's smart to "future proof" as much as you can!
https://linustechtips.com/topic/344339-first-build-need-a-psu/#findComment-4690525
Hey everyone,
heres my build http://pcpartpicker.com/p/JJm4hM
will 500w be enough? probably going with corsair power supply.
Thank you!
I would recommend the Rosewill Capstone 550w: http://pcpartpicker.com/part/rosewill-power-supply-capstone550
It's simply a better unit than the Corsair CX and the EVGA B.
https://linustechtips.com/topic/344339-first-build-need-a-psu/#findComment-4691011
