So after about a month of adjustments and decisions, I've come up with this, which should be purchased and obtained in 3 days time:
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($329.00 @ PCCaseGear)
CPU Cooler: CRYORIG R1 Ultimate 76.0 CFM CPU Cooler  ($99.00 @ PCCaseGear)
Motherboard: Asus GRYPHON Z97 ARMOR EDITION Micro ATX LGA1150 Motherboard  ($219.00 @ PCCaseGear)
Video Card: MSI GeForce GTX 980 4GB Twin Frozr Video Card  ($799.00 @ PCCaseGear)
Case: Thermaltake Core V21 MicroATX Mini Tower Case  ($85.00 @ PCCaseGear)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($135.00 @ PCCaseGear)
Case Fan: NZXT Air Flow Series 83.6 CFM 140mm  Fan  ($19.00 @ PCCaseGear)
Case Fan: NZXT FZ-200mm LED 103.0 CFM 200mm  Fan  ($29.00 @ PCCaseGear)
Case Fan: CRYORIG XF140 76.0 CFM 140mm  Fan  ($19.00 @ PCCaseGear)
Other: 3 Way PWM Splitter ($5.00)
Other: External Optical Drive ($29.00)
Total: $2455.00
Generated by PCPartPicker 2015-04-08 20:57 EST+1000
There are admittedly a few premiums being paid here:
PSU: Thinking of SLI in the future, (and the EVGA equivalent isn't in stock)
MB: I like the look, and it has ASUS's fantastic BIOS
HDD: It's still going to be used primarily for gaming, as well as general storage.
RAM: Future proofing.
CPU cooler: Future proofing and allowing sizable overclocks, while still being cheaper than similarly performing AIOs.
Case fans: Appearance
As for the query:
I'm thinking of upgrading my peripherals at some point soon-ish (well, over the next month or two), and am not really sure what sort of monitor(s) to get. Should I go for refresh rate over size or visa versa? And what is sort of the limit of a single 980 with regards to FPS at certain resolutions for some of the more intensive games?
Aftermarket 980Ti >= Fury X >= Reference 980Ti > Fury > 980 > 390X > 390 >= 970 380X > 380 >= 960 > 950 >= 370 > 750Ti = 360
"The Orange Box" || CPU: i5 4690k || RAM: Kingston Hyper X Fury 16GB || Case: Aerocool DS200 (Orange) || Cooler: Cryorig R1 Ultimate || Storage: Kingston SSDNow V300 240GB + WD Black 1TB || PSU: Corsair RM750 || Mobo: ASUS Z97-A || GPU: EVGA GTX 970 FTW+
"Unnamed Form Factor Switch" || CPU: i7 6700K || RAM: Kingston HyperX Fury 16GB || Case: Phanteks Enthoo Evolv Mini ITX (White) || Cooler: Cryorig R1 Ultimate (Green Cover) || Storage: Samsung 850 Evo 1TB || PSU: XFX XTR 550W || Mobo: ASUS Z170I Pro Gaming || GPU: EVGA GTX 970 FTW+
https://linustechtips.com/topic/343807-finalized-build-and-a-query/
i would get 2-way SLI 970's instead of an 980 or a r9 295x2 for even better performance.
Might've considered the 970s if i didn't only have 2 PCI slots to play with, this means i can get another 980 further down the line, like in 6 months or so.
Here are my opinions:
  1. PSU: Shjt. For starters, the RM series is subpar. Second 850w is a pure overkill. 650w is more appropriate FOR SLI, WITH OCs. Yup, that's right. 650w is already including some extra fat to burn.
  2. RAM: Future proofing RAM is the most stupid thing you can do. For starters, 8gbs should remain all you need for a long time. Second, even IF you need more, you can always add it later. Just save the money and invest it towards the 980 SLI in the future...
  3. Speaking of which, for just a few extra hundred dollars, you could have gotten the r9 295x2. That would have raped the single 980, with a very high price / performance. Ofc, if you go that route, you'll need the beefy PSUs. Or, you could go 2x 970 for more performance now.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
CPU Cooler: Enermax ETS-T40-TA 76.0 CFM CPU Cooler  ($52.00 @ IJK)
Motherboard: MSI Z97-G45 Gaming ATX LGA1150 Motherboard  ($189.00 @ Umart)
Storage: OCZ ARC 100 240GB 2.5" Solid State Drive  ($125.00 @ Centre Com)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE 3X Video Card  ($479.00 @ Centre Com)
Case: Zalman Z3 Plus ATX Mid Tower Case  ($59.00 @ Mwave Australia)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($125.00 @ Mwave Australia)
Total: $1770.00
Generated by PCPartPicker 2015-04-08 23:04 EST+1000
Get this instead, far more sensible and far more cost effective. I've knocked off about $600 off the total, which was mostly bullshit to be honest. The PSU is amazing. Case is sufficient and comes with 4 fans out of the box, quiet too. CPU cooler is great, and for a 4690k it's plenty. Changed the mobo for something a bit more sensible for SLI being ATX as it is, don't go SLI on mATX unless you're planning a full water cooled system. Changed up the storage too for something more economical. 970 instead of 980, and grab another when you grab yourself a very nice gaming monitor, such as the Acer XB270HU, or if you cannot get that, the Asus ROG Swift.
