Alright guys, so here is my final build plan for my PC. All prices are Canadian and from NCIX. I am shopping from this store because they price match and I can probably cut a deal to get a cheaper price. Now for what I want this PC to achieve. I want it to be a workstation (Adobe Programs), and a gaming PC. I do have plans to keep upgrading; I would eventually like to get a second 970, 16gb of RAM, another SSD and HDD, and a second monitor. So hopefully that explains my choice on the motherboard and Power supply. I also have plans on overclocking the GPU, and CPU.
Now, I know AMD is cheaper for both CPU and GPU but I am an Intel and Nvidia fan boy at heart. Plus I am not really on a cheap enough budget to want to swap them out.
Not to sure about my peripheral choices so I would love to hear what you guys think. Any help particularly on the monitor side would be huge.
I also have a Scheme if you can’t tell. I really like blue in my build so I went with the Blue, Black, and little accents of white. Finally my name for it I was thinking Stratus.
So tell me what you guys think and I am open to any suggestions.
http://ca.pcpartpicker.com/p/kXDPNG
Tower
Motherboard - MSI Z97S SLI Krait Edition
$179.99
CPU - Intel Core i5 4690K Unlocked
$289.99
GPU - Gigabyte GTX 970 G1
$439.99
RAM - G.SKILL Ripjaws X F3-12800CL7D-8GBXM 8GB 2X4GB DDR3-1600 CL7-8-8-24 1.5V Memory Kit
$79.98
Network Adapter - TP-Link TL-WN851ND
$22.99
CPU Cooler - Corsair Cooling Hydro Series H100I
$119.99
SSD - Kingston SSDNow V300 120GB
$64.99
HDD - Seagate Barracuda 1TB
$59.99
PSU - EVGA SuperNOVA 750 B1 750W 80PLUS Bronze Power Supply
$99.99
Disk Drive - ASUS DRW-24F1ST
$24.98
Case - Corsair Obsidian Series 750D
$169.99
OS - Microsoft Windows 8.1 64Bit
$119.99
Lighting - Logisys Dual Blue Cold Cathode Kit 12IN 3.0MM
$8.99
Total: 1681.85
Peripherals
Monitor - Samsung S24D390HL 23.6in Widescreen PLS LED Monitor 1920x1080 FHD 5ms 1000:1 HDMI VGA $179.99
 Mouse - Razer DeathAdder Chroma Edition Ergonomic Gaming Mouse 6400DPI 4G Optical Sensor Synapse 2.0 USB
$79.00
 Keyboard - Thermaltake TT eSports Poseidon Z/TT Illuminated – Blue Switch Edition USB Full Backlight Keyboard
$89.99
 Mouse Mat - Corsair Gaming MM200 Compact Edition Cloth Gaming Mouse Mat
$14.00
Headset - Logitech G430 Lightweight 7.1 Surround Sound Gaming Headset ON-CABLE Controls LAY-FLAT Earpieces Mic
$59.99
Surge Protector - Belkin BV108050-06-BLK Surge Protector 8 Outlets w/ 2x USB Charging Ports - Black
$16.99
Total: 439.96
Complete Build Total: 2121.81
https://linustechtips.com/topic/342973-my-first-build-suggestions/
With a $1700 build you should fit in a gtx 980 and maybe skimp a bit on a few other things.  with 438 on the 970 you are getting into gtx 980 territory there anyways on the price.  You could probably get a cheaper mouse too without losing much on the quality.  Maybe the case too, but its all up to you
| 2014 Retina MacBook Pro 13" |
My gaming desktop -- |Intel Core i7-3820 | ASUS P9X79 Deluxe | 16gb 2133mhz G.Skill Ripjawz X | ASUS DUAL GeForce GTX 1060 6GB | Fractal Design Define R5 | Seagate Barracuda 1TB 7200rpm HDD | SeaSonic 760XP2 | Xigmatek Gaia CPU Cooler | LG22MC57HQ 1080p Monitor | Azio MGK1 Keyboard | Logitech G300s Mouse | HyperX Cloud Headset | Windows 10 Pro Insider |
