motherboard HELP!
Solved by nightlitezzz,
Which one were you referring to? the g45 gaming edition?
ya ive heard good things but is it reliable?
The LK is one of the best low budget Z77 motherboards IMHO. Excellent overclocking and features. If you can stretch your budget a little more I would personally jump for a Gigabyte Z77X-UD3H. Extremely well made board, if you don't want that one then you can get the MSI 45 Gaming.
