Hi there,
I am in the middle of deciding which parts I'm going to buy for my next gaming PC.
It's going to be based on the Corsair Obsidian 250D Mini-ITX case, and this are (probably) going to be the specs:
  • i5 4590
  • MSI H97I AC
  • WD Blue 1TB HDD
  • Crucial MX100 256GB ssd
  • Kingston HyperX Fury red 1866Mhz 2*4GB ram
  • Seasonic M12II Evo 520W PSU
  • The GPU is yet to be decided (Probably a GTX 970)
I was wondering if a blower style cooler was necessary in an ITX case, and if it would affect the temperatures of other components much. The point is, there aren't really a lot of 970's with a blower style cooling on the market. (And those that do aren't very good looking. If only nvidia produced the 970 with their reference cooler :C).
So yeah, would any aftermarket 970 do the job as well? (While still keeping the system reasonably quiet?)
https://linustechtips.com/topic/342723-gpu-cooling-in-mini-itx/
You can get the reference 970 at Best Buy in the US or OverclockersUK in the UK
"Rawr XD"
https://linustechtips.com/topic/342723-gpu-cooling-in-mini-itx/#findComment-4668904
If I were you, I would wait for a HTPC Mini ITX Esq case before going Mini ITX. Though to answer your question OP, you are going to want a Blow style cooler. I used a Micro ATX case (Fractal Design Core 1000) with a Open Air R9 270x, and that thing reaches 93c. My 780Ti which is much beefier and has a much higher TDP (250W) only hits 82-83c under full load and it uses the stock Blower cooler. Definitely Blower Coolers are better.
My System has a Intel Core i7 4790k @4.5ghz Cooled by A Cooler Master Hyper 212 EVO With a MSI Nvidia GeForce GTX 1080 Founders Edition and 16GB of Corsair Vengeance 1600Mhz Memory.
https://linustechtips.com/topic/342723-gpu-cooling-in-mini-itx/#findComment-4668971
Alright thanks, I think I'll have to start searching the shops for a reference 970..
https://linustechtips.com/topic/342723-gpu-cooling-in-mini-itx/#findComment-4669101
I think it will. You don't have to worry too much I guess.
I'm using a mITX case, Coolermaster Elite 130, much worse ventilated than a corsair 250D if you ask me.
My spec: gigabyte wf2 gtx960, i7 4790s (stock cooling)
While playing the witcher 2, max out everything minus ubersampling, I get 55C (131F) CPU temp and 71C (160F) graphic temp. Ambient temp 30C (86F). And that's with a case even reviewer says "could have better air circulation".
GPU fan only spins at 33%, and barely audible. My old PSU is probably louder than everything else combined. Things are just warm to the touch, nothing scary. Haswell + Maxwell, heat is probably the least of my concern.
https://linustechtips.com/topic/342723-gpu-cooling-in-mini-itx/#findComment-4671782
I think it should be fine. Probably the same as a giant case...
G3258 @ 4.5 | 8GB Team Vulcan RAM | 128GB Kingston V300 SSD (I didn't know what I was doing when I bought it) | MSI H81I Motherboard | Corsair H55 with Noctua NF-P12 | EVGA SSC GTX 960 4GB | OCZ 550W Fully Modular PSU with Noctua NF-A14 | Cooler Master Elite 130 (Soon to be something cool)
https://linustechtips.com/topic/342723-gpu-cooling-in-mini-itx/#findComment-4671810
