I'm  supposed to make a payroll c++ program and I need to write the employee data in .txt file which I will you to counter the number of employee but every time I run the program the data in .txt file get deleted how to fix that ?
you need to open your file in "append" mode, not "write" mode
https://linustechtips.com/topic/342553-c-project/#findComment-4669211
