Recently got my build up and running and made a custom curve in corsair link v2. Thing I noticed though is the fans staying at 500-700 rpm when doing the stability tests.
After looking I noticed that its monitoring the water temp instead of the cpu and I don't have an option for cpu. It also wont let me add one.
It is also monitoring my corsair SSD which it added automatically.
Both fans are plugged into pump. Pump is plugged into usb header, cpu 1 header and sata power.
CPU is an i7 4770k
MOBO is Z87 GD65
OS is windows 8 pro 64-bit
Was told on corsair forums that it doesn't work for haswell cpu temps.
group it by H100i temp for now...they havnt implemented 4770K cpu temps yet
i7-4770k 4.7Ghz delidded w/ H100i | Z87-GD65 | 8GB Mushkin Blackline 1600Mhz 9-9-9-24 | Asus GTX 780 DC2OC@1241/1772 | Corsair AX760 | Samsung 840 Pro 256GB | Corsair Force GT 60GB | Hatachi Laptop 360GB HHD | HAF 922 | Win 8.1 64-bit | Razer Ouroboros |
Siberia V2 | Logitech K120
Xbox360 | Tritton 720+ | Xim3
https://linustechtips.com/topic/34202-h100i-not-detecting-cpu-temps/
Could you post a screenshot ?
strange... update the program maybe? and chenck the cables are in place
He is the hero this forum deserves but not the one it needs right now.So we'll hunt him because he can take it because he is not our hero he is a silent guardian
a watchful protector A Dark Knight
Is your CPU being detected with other 3rd Party Software such as HWMonitor?
Have you installed your motherboard drivers?
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
It's the newest version on the h100i page.
Yes, has cores 0-3 and package.
Are you getting a motherboard reading for that or just the Core readings? Could you post a screenshot of your HWMonitor?
Also have you installed all your lastest motherboard drviers?
edit: yes I have the latest drivers. Used msi live update and all it shows me to download now is optional stuff like google toolbar and norton.
edit2: stuff it wants me to download left is: Command center, super raid, google toolbar, lucid virtu, norton internet security, safesync
<PIC>
Is your BIOS up-to-date?
If it is then I really don't know what the problem could be. You could try your luck in the Corsair forums as they could probably report this as a bug directly to their software team if it really is a bug in the Corsair Link software.
http://forum.corsair.com/v3/forumdisplay.php?f=155
Yeah its up to date (v 1.3). I'll try my luck there, thanks.
Edit: Seems there is a firmware update to fix a detection issue. Extra thanks for the link, I wasn't able to find the firmware earlier, instead found a post of someone saying it came with the corsair link.
E2: Nope, all that did was turn the LED on.
Perhaps re-installing it.
